seth247
- August 23, 2007
- Tulsa, Oklahoma
- '92 XLT 4X4
Heres an excerpt from that article:
The 1998+ revision of the mlps sensor is not electrically compatible with a 1992-1997 pcm. 92-97 vehicles use a resistive multiplex setup to inform the pcm of the driver selected gear, 98+ vehicles use a "bullet proof" switch that has numerous normally open switches in parallel. You will notice is you have the wrong mlps sensor because the "old ones" have 8 pins, the "newer" ones have 12 pins. Make sure to properly calibrate the mlps after installation.
just checked mine, it is a 12 pin.
