Message center addition
J8McMahon
1998 Ford Explorer XLT V8
I know, I'm posting a lot today. My 98 explorer did not come with a message center in it. I wish to purchase one from somewhere and install it into my explorer so I can have system checks, and economy, and stuff like that. Is it possible? Thank you in advance!
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
koda2000
x
In addition to the msg center, you will also need the wiring, a different oil pan, various sensors and a 24 gal fuel tank to have everything work. I believe @vroomzoomboom added the message center to his Sport and was not about to get the fuel level stuff to work correctly because the Sport has a 17 gal fuel tank. A lot of work for not much return.
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Not so bad, but you haven't followed up and responded to ANY replies from the threads you've started. :banghead:
vroomzoomboom
Elite Canuck STOCK SUCKS!
selkirk, manitoba
98 supercharged 347 sport
you are correct. after digging, and digging on how to make it work with a sport, i couldnt find a thing on how to do it. i believe 99sportx said he did it to his, but couldnt remember what he did so i gave up. if your putting one in, i also remember seeing something that you want to get one that came from the same year, and had the same motor to work. however, i am sure i have the same year, but now i have a v8 in mine, and it was a v6 went i did it and everything works the same, with one exception. when i put the stroker in, the average mpg changed and i cant figure out why. once again, just something i am living with now.
LoquetusofBorg
"Resistance is Futile"
Location
Eureka
Eureka, Illinois
98 Explorer Sport-Limited
Yes, I also put one in my 98 sport. It works great. There is a write up here on the forum to install it using your existing wiring, but it will be much more time consuming to do. just get the wire harness from the donor rig, it will be less work- sort of. I am going to get rid of my message center because it takes up a lot of valuable real estate on my console for other things I want to put in. You can buy a scan gauge do do the same thing and a lot less work.
Loquetus
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
Ditto, Eric(99Sportx) did it here first(member later had done that and posted on Car Domain, his was a Ranger(302, Eaton blower, Torsen rear diff etc). I don't think the oil pan sensor he worried about, he didn't mention it. But I believe he detailed most all of what he did in his many upgrades(V8, Mountaineer front end, message center, EATC, now an LS engine).
I'd hunt his threads and see if there's more detail in them. I recall there is a difference in the dash cluster wiring of the V6 versus the V8, affecting tach at least. That's a long ways back, 2005-6ish I think.
J8McMahon
I don't care really for the fuel economy perk as much as like taking advantage of the computers to show the sensor data like system checks and stuff. Also, apologies for not responding immediately, I have limited internet access...
vroomzoomboom
selkirk, manitoba
J8McMahon
Okay, thank you for the help!
P Message Center Help Stock 1995 - 2001 Explorers 5
B Message Center Weirdness Stock 1995 - 2001 Explorers 0
GingeRed11 Message center install? Stock 1995 - 2001 Explorers 14
LoquetusofBorg 96/97 Message Center Stock 1995 - 2001 Explorers 2
H Message center. Stock 1995 - 2001 Explorers 9
M Message center help Stock 1995 - 2001 Explorers 0
S battery cables listed as w/o message center verses w message center Stock 1995 - 2001 Explorers 2
koda2000 how hard would it be to install the driver's message center Stock 1995 - 2001 Explorers 11
1 Message center question... Stock 1995 - 2001 Explorers 2
N Message Center in 1995 Ford Explorer Stock 1995 - 2001 Explorers 0
R aTCS & Message Center no power/blank Stock 1995 - 2001 Explorers 0
1 Message center bulbs/lights question Stock 1995 - 2001 Explorers 10
9 Message center "check engine temp" Stock 1995 - 2001 Explorers 25
I Message center flashing with turn signal Stock 1995 - 2001 Explorers 6
M is it possible to add a center message center to 2001 xlt? Stock 1995 - 2001 Explorers 0
J Removing ARC warnings from message center Stock 1995 - 2001 Explorers 0
M How To: Get rid of the annoying beep/chime from the message center Stock 1995 - 2001 Explorers 2
D Wiring in a Factory 6-CD Changer and Message Center Stock 1995 - 2001 Explorers 4
B Anyone else have problems with the Message center? Stock 1995 - 2001 Explorers 3
K 98 explorer message center locked up Stock 1995 - 2001 Explorers 2
C 2000 Mountaineer Message Center Lights...HELP!!! Stock 1995 - 2001 Explorers 0
W Message Center/Climate Control Electronics Stock 1995 - 2001 Explorers 4
R Message center installation Stock 1995 - 2001 Explorers 7
M Message Center Install Stock 1995 - 2001 Explorers 2
N Explorer message center interchangeability Stock 1995 - 2001 Explorers 2
D Low Washer Fluid warning from Message Center Stock 1995 - 2001 Explorers 2
Z Adding a message center. Stock 1995 - 2001 Explorers 6
S message center: how accurate is it? Stock 1995 - 2001 Explorers 10
R Message center installed!!! With WRITE UP and PICTURES!!! Stock 1995 - 2001 Explorers 54
R HELP with message center please!!! Stock 1995 - 2001 Explorers 0
M Message center problems Stock 1995 - 2001 Explorers 4
D message center Stock 1995 - 2001 Explorers 3
T Message Center Question Stock 1995 - 2001 Explorers 4
R Message Center 98 Retrofit Stock 1995 - 2001 Explorers 3
B Message Center Light Bulbs Stock 1995 - 2001 Explorers 0
T Warning chimes from the message center. Stock 1995 - 2001 Explorers 4
9 DIY:Message Center Installation Stock 1995 - 2001 Explorers 52
vroomzoomboom message center sensors Stock 1995 - 2001 Explorers 31
MarT Message Center - Inaccurate Fuel Level Stock 1995 - 2001 Explorers 5
9 Message Center Stock 1995 - 2001 Explorers 2
R How to add a message center to your explorer Stock 1995 - 2001 Explorers 2
Y Message Center Problem Stock 1995 - 2001 Explorers 4
K Message Center Help Stock 1995 - 2001 Explorers 1
V message Center question... not your typical question... Stock 1995 - 2001 Explorers 10
J Message Center - Attention sticker on back Stock 1995 - 2001 Explorers 2
G Installing a Digital Message Center on a 99 XLT ... is it possible? Stock 1995 - 2001 Explorers 4
S Center Console Message Center Bulbs Stock 1995 - 2001 Explorers 11
S Message Center Wiring Stock 1995 - 2001 Explorers 0
M Message Center - Need Help!!!!!! Stock 1995 - 2001 Explorers 3
M Help...Anyone wire-in a message center into the center console? Stock 1995 - 2001 Explorers 2
Similar threads
