The_smithsonion
- September 4, 2018
- Waco
- 96 explorer 4x4 4.0 ohv
So the problem started after i replaced the upper intake manifold gasket, it was causing a vacuum leak.
When starting , it sounds like itlle crank for a second then catch on somthing and recrank , if it decides to start itll run really rough and want to die but then level out after a minute if it stays running , and run great after that with the misfire in cylinder 4 witch i think has low or no compression , seems to run better after 1500 rpm aswell. Any insite would help no codes just low voltage light
