According to the below I can use Mercon V Syntheic Blend, but not Mercon V Synthetic in my transfer case.
[url]http://www.fcsdchemicalsandlubricants.com/Main/category.asp?select=[Transmission%20Fluid]
[/URL]
MERCON® V Automatic Transmission and Power Steering Fluid
* Motorcraft® MERCON® V is a premium-quality automatic transmission fluid designed, engineered and recommended by Ford Motor Company for use in Ford, Lincoln and Mercury vehicles that require either MERCON® V or MERCON® type fluid. This product also provides excellent performance in electronically controlled automatic transmissions.
* Motorcraft® MERCON® V is manufactured with high-viscosity index, premium-quality, hydroprocessed base oils and specially designed performance additives, which provide excellent shifting characteristics at high and low ambient temperatures, excellent thermal and oxidation resistance and good low temperature fluidity. It provides wear protection and inhibits the formation of gum, sludge, lacquer and foam. It also provides protection against rust and corrosion. It is dyed red for ease of leak detection.
* Do not use in applications where MERCON® SP, MERCON® LV, Continuously Variable Chain Type Transmission Fluid, Motorcraft® Premium Automatic Transmission Fluid, FNR5 Automatic Transmission Fluid or Type F Automatic Transmission Fluid is recommended, or in transfer cases.
* Motorcraft® MERCON® V is suitable for use as a hydraulic oil in a wide variety of industrial applications that call for an ISO 46 or SAE 20W viscosity grade hydraulic oil
* Refer to the Motorcraft® MERCON® V specification sheet at
www.motorcraft.com and
www.fmcdealer.dealerconnection.com for additional information. For MSDS information call 1-800-448-2063
* Note: MERCON® V Automatic Transmission Fluid is available in bulk quantities at substantial savings. Use of bulk oil products is environmentally proactive. Contact your FCSD Aftermarket Account Manager, an approved Motorcraft® Bulk Oil Distributor, or
www.Motorcraft.com for details.
Synthetic Blend MERCON® V Automatic Transmission and Power Steering Fluid
* Motorcraft Synthetic Blend MERCON® V Automatic Transmission and Power Steering Fluid is a high-quality automatic transmission fluid approved and recommended by Ford Motor Company. It was developed for use in the newer electronically controlled automatic transmissions built after 1989 and power steering systems built after 1998 requiring MERCON® V or MERCON® fluid
* Motorcraft Synthetic Blend MERCON® V Automatic Transmission and Power Steering Fluid is formulated with high-viscosity index, premium-quality, synthetic/hydroprocessed base oils and specially designed performance additives. It is specifically formulated to provide improved shifting characteristics at high and low ambient temperatures, excellent thermal and oxidation resistance, and good low temperature fluidity. It provides wear protection and inhibits the formation of gum, sludge, lacquer, and foam. It also provides protection against rust and corrosion
* It is especially effective in applications where high temperatures are a concern. Due to its excellent thermal, oxidative, and shear stability, this fluid is required in manual transmission applications such as Mustang with G1 manual transmissions and F/Eseries with TR 3650 and ZF S5-47 manual transmissions
* Formulated for powersteering systems to provide excellent low temperature fluidity as well as improved high temperature thermal stability for use in extreme conditions in all seasons
* Do not use in applications where MERCON® LV, MERCON® SP, Continously Variable Chain Type Transmission Fluid, Motorcraft® Premium Automatic Transmission Fluid, FNR5 Automatic Transmission Fluid or Type F Automatic Transmission Fluid is recommended.
