- June 16, 2003
- Humboldt, KS
- 2000 Mounty
This is very good discussion, and bears further investigation. Try this. Call C&L or Granetelli, or any other mafs supplier, and order a new mafs. They will ask a lot of questions, ( injector size, mods etc. ), one of which is about the air intake. If you have an aftermarket intake system, they will match the meter. If you have a custom built or home made, they would prefer to have it to tune your meter. Now ALL I was saying is changing what is in front of the mafs can alter its output signal. Just radiator fan wash is a BIG problem if it hits the filter right. As long as the aftermarket supplier has done thier homework, it will be ok. but as far as your mafs is concerned more air in = more fuel out.
Now as far as the sampling tube goes, on a c&l meter you change it for different injectors. On a pro-m you have to mediablast a resistor, or go with a maf programmer. When I saw the pro-m calibration article in H/R magazine in '03 they had 126 mafs setups for Ford alone. not for different engines so much, but for different air filter boxes. And yes I've seen personally from experimenting with this, An elbow in front of mafs must be at least 4 diameters away from it. I saw 200mv of ac distortion (rich ) running 4" intake elbow instead of my built for maf filter, which is the only one I can run to minimize sample tube distortion.
just fuel for thought.
BTW it wasn't this that burned a piston, it was my quest for leaner, and accomplished through maf tuner adjustment error on my part. ( she was screaming for a second though lol)
My exhaust is the dual out flowmaster. My wife hates it, and I'm slowly getting tired of it. It is very loud. You'll need a good stereo
