Certainly!
Although it's been 10 months since I did the mod, I've only put about 3K miles on the truck (mostly highway and none off-road). Thanks to the light rail system in and around Chicago, there's no reason for me to drive it much.
1 - Additional Problems/Solutions. I have not had any issues with the springs. I have heard from other members that have experienced "fanning" of the leaves. I'm not quite sure what causes this but I suspect it might have to do with mixing and matching of various leaves. In other words, keep the packs together as a unit. Since spring steel has a 'memory' individual leaves take on certain subtle differences with respect to twist and arch. When the leaf above and/or below isn't from the same pack, the leaves may not "mesh" well together which causes them to fan. Retaining straps would resolve this but would also limit flex if you plan this mod for off-roading (as I did). I am not running retaining straps but have some new ones of anyone needs some.
2 - Evaluation of the Ride - This will be pretty subjective since we all experience things differently. As I originally mentioned, the ride is much firmer than stock. I owned an '89 F150 and I find the ride to be similar. The Explorer ride is a little softer due to the additional body mass over the rear of the truck. I really like the OME shocks and think they are worth the extra $$. I do not haul or tow anything of significant weight. I do have a small utility trailer for hauling motorcycles but I barely notice the additional drag on the motor let alone any effect on the rear suspension. I would think you'd be able to tow a trailer with more tongue weight or haul heavier objects without noticing a large amount of rear spring "squat".
3 - Performance versus Factory - Again, as above, a firmer ride than stock. I'm curious to see what it rides like with a load of off-road tools/spares/gear since that was the reason for the mod, in addition to lift, in the first place. I'll have to let you know as I plan a few off-road trips next year.
4 - 4 Door versus 2 Door - I've never ridden in a Sport. I do know that riding in a Zeep can be pretty rough due to the short wheelbase. I've read several threads about upgrading the mono-leaf to a four door leaf pack. I would think that the Sport might start to ride quite rough with the full five leaf F150 pack. Someone might experiment with a four leaf F150 pack in the Sport.
Editorial: I will say this, I see a lot of members considering or installing AALs, Double AALs and shackles. After an extensive email conversation with Mike Eaton of Eaton Detroit (excerpts of the conversation appear in the original post), installing a double AAL will result in a pretty stiff leaf pack. If your intention is lift without flex, this is a good option. If you need flex, it's best to stay with as few leaves as possible. A single AAL would work but you're still dealing with the original leaf pack. Chances are this will provide some lift (1" ?) and may not be worth the effort. The 'second' F150 leaf almost fully supports the main Explorer leaf which keeps droop near the mounting eyes to a minimum (thanks to GJarrett for discovering that). Shackles are the easiest way to get your truck some lift thru the suspension. It's also the easiest way to add more instability to the vehicle. As we all saw recently with BBQ_Hotdogs, these trucks have a high CG and have stability issues when it comes to high speed maneuvering. Providing lift with the torsion bars and leaf packs raises the truck but brings the CG of the frame closer to the CG of the body. With those two CGs (known as a 'couple') closer, the suspension (sway bars, too) is better capable of 'catching' any lean of the body (before that force can cause a flip). You do not get this benefit with shackles. Granted the amount of time/effort/money with a shackle install is much less but I don't think it's worth it. (I'm off the soap box now).
