- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
Almost all sunroofs have a drain pan around and below the roof seam, to catch and drain water. The pan typically has four drains, holes at the corners where a simple rubber hose is clamped on, and the hose leads down the pillar next to it. The hoses generally will never clog up, but the drain hole of the pan will be smaller than the hose, and those do clog up. The hoses may come loose from the pan drain hole/nipple, that's usually from the clamp being weak, or someone pulling on the hose.
The rear drains should be going down the "B" pillars, front go down the "A" pillars. Check to see if you can find all four of the hoses under the vehicle. They should be visible normally, just the ends showing below the pillar areas. Id a hose comes loose, that should end up with a bad water leak on the headliner.
