ryboj
- December 20, 2010
- Northern NV
- '92 Dora XLT 4x4 5Spd
Guys, trying to determine viability of various engine swap options, in gaining a V8 powertrain, should I proceed to move forward with this phase of the build in the not so distant future. Seems some believe it easier to perform a swap on my first gen vs buying a second gen with a V8 and switching all my first gen long travel TTB front and rear section over to it.
The 5.0 is a solid option, and tried in true; however, that doesn't mean it's the only realistic and cost effective option, no?
Would any of these options be viable in your opinion below, since these are plentiful across yards and or purchasing whole vehicles for a bargain in some cases that have such examples. Or what larger issues come to mind?
Now, I don't mind staying with a manual trans, but might prefer auto for a V8 for trails/desert/dunes. So, if a manual, maybe a ZF or NV4500. Auto's, I'm open to anything solid, reliable and affordable. TC, prefer a manual unit and whatever can be made compatible and or in conjunction with adapters.
Dodge:
1: 5.2 (318) or 5.9 (360) Magnum
Note: I didn't include a 5.7 Hemi here, since these are not considered affordable used engines in my opinion, nor is the '09+ 4.7's
Toyota \ Lexus (more compact DOHC V8's):
1: 1UZ-FE 4.0's, the 1989-'94's, first gens, the most robust 4.0's they built internally speaking
2: 2UZ-FE 4.7's
Not sure the 4.3's would be as good in a heavier truck and are more costly because of people using these for drifting engines, etc.
I also excluded the Infiniti's because of the sheer size of those 4.5's, just too large
GM:
1:Older Caddy Northstar V8's (very affordable now and a lot of support from the last 2 decades of those that used these in the desert for buggies, etc) Never mind, just not reliable enough really and only select year and rwd models work.
2: Early gen 5.3, like an '04, as I might have a work truck I can take everything from potentially, but would need to be freshened up and it's not for sure though
Note: 6.0 LQ9 would be awesome, but definitely heavier unit and likely overkill for this application and not affordable used
Believe or not, also thought about using a Saab engine, a 2.3 I4 or a 2.8 V6, since they make big power reliably and easy to support, but not sure I'd have any options on transmissions, etc. These are CHEAP and plentiful. Big power potential and uber reliable when setup right and maintained.
Any thoughts on these ideas?
Dodge:
2: 2UZ-FE 4.7's
GM:
1:
