Explorer Forum Covers the Explorer ST, Explorer Sport, Explorer Sport Trac, Lincoln Aviator,
Mercury Mountaineer, Mazda Navajo, Ford Ranger, Mazda Pickups, and the Ford Aerostar
Register Today It's free!
- Forums
- Generation Specific Forums
- 1991 - 1994 Explorer Ranger Navajo 1st Generation
- Modified 1991-1994 Explorers
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an alternative browser.
My A4LD - M5OD Conversion Thread
- Thread starter Freshmeat
- Start date
Add an avatar, upload photo attachments, and more!.
Freshmeat
- July 26, 2008
- Denham Springs, LA
- 1994 Ranger STX SC
Just scored a replacement intake tube. Going to swap it out in a moment and drive it to work tomorrow. Still need to install the passenger seat, center console, and kick panels, but that's no rush.
Freshmeat
- July 26, 2008
I haven't had a chance- been working and preparing for my trip to Mexico. I didn't even get to install the air tube tonight, which takes all of five minutes. I do hope to get it all finished before I leave Saturday but it's a very low priority, at least until I return from my vacation.
Freshmeat
- July 26, 2008
I installed the air tube and drove it a little bit more tonight. I'll drive it to work in the morning and see how it does for distances longer than half a mile. I almost broke the shifter- going from my Kenworth at work with a LOOOOONG throw to this thing is a crazy huge difference. I'm sure the brand new bushings and cover (at Anime's recommendation- thanks for that, man!) are what makes it so great. I was hoping to figure out a way to make a short throw shifter because my Ranger shifter was sloppy. I guess I just needed to rebuild it!
Thanks for all the information, everyone- Foxracin, I'm planning to do that jumper soon and I'll let you know how it works out for me.
Freshmeat
- July 26, 2008
I returned from Mexico yesterday. Replaced the throttle position sensor, which instantly improved the driveability. Tonight I'm going to clean it up and finish installing the interior, then I'll dig into the 4x4 wiring tomorrow.
Freshmeat
- July 26, 2008
The oil pressure and oil level wires on the transmission harness are stripped at the plug and wound around each other. I'm going to either disassemble and repair the plug or get one at the junk yard and splice it in Tuesday. I also need to reattach the engine-to-firewall ground to the block, likely also Tuesday. Plenty of small steps left, but it's certainly coming along.
It's in desperate need of a power steering pump. I'm planning to run a Saginaw and feed the low pressure side through the old transmission cooler. Possibly this weekend.
Freshmeat
- July 26, 2008
Woot! It's all officially back together!
I ended up permanently grounding the red/white wire until I can get my own diagram and analyze how I want to handle it. No offense, but not knowing exactly which wires do what and getting conflicting answers I figured I'd go the safe route. It now has 4LO.
I also ran the antenna wire for my CB while I had things torn apart.
I have a laundry list of things to do now, but the transmission swap is complete and I am absolutely thrilled with the results.
- August 1, 2008
- MO MO
- 94 & 95 XLT's
This thread is going to be a great source of info for me when I do my manual swap. Mine will be a little different being a 2nd gen. But, being it is a 95, I am OBD1 like yours. The electronics/wiring are what I am going to have trouble with, I might be asking some of you a few questions when I get around to this, so Thank You in advance! I did get a message from Henson Performance, and he cant flash a program, BUT, can install a pre-programmed chip to ignore the transmission altogether. I just have to figure out which is more cost effective.
91ROKKRAWLER
- December 6, 2007
- Bend, OR
- '91 Xploder
You can just swap the manual pedals into your existing pedal hangar/dash brace. Saves you the work of pulling the dash out... You'll have to unbolt the e-brake pedal assembly and swing it down out of the way, and may have to disconnect and pull the large main harness bulk head connector out of the fire wall to clear the way to slide the clutch pedal in.
Wish i'd seen that BEFORE spending two days TRYING to pull the pedal support just to find out it takes less than an hour to slide them off.
Thanks everyone for your help that participated in this thread. i will have the pedals in my explorer tomorrow.
91ROKKRAWLER
- December 6, 2007
- Bend, OR
- '91 Xploder
whats the 2 2 wire plugs on the tranny?
91ROKKRAWLER
- December 6, 2007
- Bend, OR
- '91 Xploder
How do i bypass those and just make my clutch lockout work? So i can start it by clutch pressed only. Would i need either of those plugged in?
Similar threads
- Replies
- 33
- Views
- 9,769
- Replies
- 75
- Views
- 67,233
