- February 8, 2003
- Sacramento, CA 95827
- 1992 XLT
Ok time to start putting parts back in. I am going to need to make some measurements for select fit bearings, and also am still fussing with the input shaft bushing. I don't like the clearance and may replace it - so I am sort of "dry assembing this" at this point. That means for those still reading, if there is something you want to see more clearly, holler and on the second go around I'll try and highlight it.
The first thing in (onto the new race) is the rear sprag or rear one way clutch, different names for the same thing. Most books omit a CRITICAL point. If it is ONE way, WHAT WAY SHOULD IT TURN WHEN INSTALLED? The answer is clockwise, so when you reach in and are installing it, do so with a clockwise rotation
I've added an arrow (crude as it is) to demonstrate this:
If you look at the center area (I call it the "snout") you will see that there are two sets of three indents. The outer one (with irregularly spaces) is where the tangs on a thrust washer go. Here that washer is installed, you can see the tangs have engaged the little slots.
This rides against the back of the output shaft ring gear. That in turn splines thru the output shaft, so I slid the output shaft in thru the case bushing in, and put the ring gear on top of it:
Now you add the NEW snap ring. Since I will be taking this apart I reused the old one, but in the final final, it will be a new one. On top of this there is an oil dam for the 4.0 (improves rear planetary oiling) and for now I am leaving that off. I'll show that on the final assembly. Here's the ring gear, snap ringed into place. That also holds the shaft in the case from now on.
Next the rear planetary. Make sure you have a steel 6 pinion version. My old one was crumped, so this on is brand new. A thrust washer clings to the back with 6 prongs, like so:
Insert this into the ring gear, and you have a complete (sans front thrust washer) rear one way clutch installed. (Have a beer)
