- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
Be careful of where you get an engine, or work done to fix the leaks. Some new member here paid $4200 for what was supposed to be the rear main seal, oil pan gasket, and one manifold. The dealer(actual dealer service) left some wire connection loose or off(O2 I think it was), with a CEL they got tired of working on it.
For an engine, first look around and see if you can find a good mileage 302 from a 1987-1992 Mark VII. Those are all HO 302's, so well cared for and never shifted above 4500 rpm. If you could find that, change the main seals, and swap your heads and camshaft into it. The cost to rebuild an engine has gotten crazy lately.
