I will keep this first post updated with my progress so people don't have to weed through all the boring crap associated with these buildup threads.
So far I have:
Front axle:
Dana 60 35 spline kingpin high pinion from a 79 f-250/350
detroit locker
dedenbear knuckles
5.38 gears
alloy usa shafts
longfield u-joints
warn hubs (should have went with drive flanges)
high steer arms with full hydraulic steering
Steering:
2x8 double ended cylinder from surpluscenter.com
steering valve out of an old forklift
misc. hoses and fittings from surpluscenter.com
Rear axle:
Dana 60 30 spline low pinion from a 79 f-250/350 (should have went with a 14 bolt)
full spool
5.38 gears
Disk brake conversion
Tires/wheels:
16.5" hummer h1 8 bolt double beadlocks recentered with custom stazworks centers.
36x12.50 wrangler rt II 6 ply military bias tires(sucky but cheap)
Things I need still:
new rims and tires and hopefully she wont shake so bad at 60mph.
Got axles
Got a new truck so i can dismantle the explorer and tow it around when i'm done.
Welded Diff covers
Rear axle almost done
Front axle almost done
Rear axle under truck
Welding up rear driveshaft (yes, it is square)
Machined parts for the upper control arms
Made coil buckets
Made lower control links
Mocking up Front axle and welded up hydraulic ram mount.
Got myself a forklift orbital for my hydraulic steering
welded on lower control arm mounts
Dropped the front IFS
Sent it to the scrap yard
IFS gone
Front axle starting to go in.
off jackstands
Took out the A/C system and cruise control. Also removed ABS brake controller, but I ended up having to put it back in later for the speedo to work.
Mounted new/slightly larger fluid reservoir for the hydro system.
Mounted the stock power steering cooler for the hydro system
Got this mounted in the engine bay where the A/C junk used to be
Had to chop down this thing first though.
Made some tie rods out of 100% grade A beef.
Installed hydraulic ram and tie rods.
View of the filter, and you can see the high pressure hose running from the pump down to the steering valve.
This is how i connected the stock steering wheel to the steering valve. 3/8" swivel
Better view of the steering valve.
Poor planning caused track bar issues
Made a new track bar bracket
Cut off first track bar bracket
Plated for good measure
Welded on new track bar bracket. Still had minor interference so i move the axle forward another 1/2"
Also started putting on shocks.
Tacked a tone ring to the rear d60 carrier
Reinstalled tone ring sensor so i can get speedometer back
blah blah blah tidied things up and poof.... an explorer that can only go 55mph now. If you have questions, just ask or PM me.
So far I have:
Front axle:
detroit locker
dedenbear knuckles
5.38 gears
alloy usa shafts
longfield u-joints
Steering:
Rear axle:
full spool
5.38 gears
Tires/wheels:
Got axles
Welded Diff covers
Made coil buckets
IFS gone
off jackstands
