Need Foglight wiring diagram...
vp6799
Massachusetts
2014 Explorer Limited
Anyone have access to the 5th gen wiring diagram?
I would like to disable the fog lights turning off when the high beams are on function. I've done it to my 99 ranger, 02 explorer, and 04 expedition just by bending 1 tab on the foglight relay, but with all of the electronics in the new explorers, i'm afraid of shorting something out by accident. So the smart thing to do, is check the wiring diagrams out first.
My explorer is a 2014 Limited with halogen headlights and auto lights (if it matters).
Thanks
Vic
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
Thanks
Vic
That would be illegal in some states. There is a reason they turn off when the high beams are used. Also, not really sure what they would add to the high beams.
vp6799
Massachusetts
It's not illegal in MA. The only thing you can get cited you for here is if you drive with your high beams on within the city.
I'm not looking for better lighting benefits. What I get out of it is the fog light HID ballasts not switching off and on with a quick turn around. Since it's not good for the ballasts. They stay on if I flash someone to let them go.
Vic
sheltonfilms
Hoover, AL
2013 Limited 3.5L
Thanks
Vic
Not gonna be able to do it. The body control module has an internal relay that is controlled by the processor. The relay contacts are soldered to the board.
vp6799
Massachusetts
That's what I thought and confirmed with the link that swashawaii posted above. That sucks, oh well it stays the way it is...LoL
E Need help in 2019 xlt audio Modified 2011- 2019 Explorers - Tuning & Mods 0
S Need Help - Explorer Not Shifting Up When Floored - Bigger Tires 295 45 20 and SCT Tune Modified 2011- 2019 Explorers - Tuning & Mods 5
F HI! I need help with Wheels and Tires!* 2017 Modified 2011- 2019 Explorers - Tuning & Mods 0
F Need new speakers Modified 2011- 2019 Explorers - Tuning & Mods 0
Zohli Need Aftermarket Horn Help Modified 2011- 2019 Explorers - Tuning & Mods 9
SurrealOne Need advice Modified 2011- 2019 Explorers - Tuning & Mods 5
L Do you Need Help with your 3BAR Install? Modified 2011- 2019 Explorers - Tuning & Mods 0
1 Need help with figuring out how to install separate fusebox Modified 2011- 2019 Explorers - Tuning & Mods 0
C Need help. Lowered Explorer today. Modified 2011- 2019 Explorers - Tuning & Mods 0
J Alright guys, I need this grill. Modified 2011- 2019 Explorers - Tuning & Mods 14
R RetroFitted Headlights - need your opinion Modified 2011- 2019 Explorers - Tuning & Mods 24
I Vendors, we need rear wheel bias Modified 2011- 2019 Explorers - Tuning & Mods 14
V I need someone's stock Sport center resonator Modified 2011- 2019 Explorers - Tuning & Mods 0
I Need to know offset and backspacing of sport wheels Modified 2011- 2019 Explorers - Tuning & Mods 2
I HELP! Need 12V accessory power Modified 2011- 2019 Explorers - Tuning & Mods 8
R Need a good shop in Queens, NY Modified 2011- 2019 Explorers - Tuning & Mods 4
J Need ? No want some led's Modified 2011- 2019 Explorers - Tuning & Mods 9
C Need to upgrade base crappy 6 speaker system Modified 2011- 2019 Explorers - Tuning & Mods 7
S Need Advice for Aftermarket Gear Modified 2011- 2019 Explorers - Tuning & Mods 2
T Need Advice Modified 2011- 2019 Explorers - Tuning & Mods 15
M Need Headlight Removal Help Modified 2011- 2019 Explorers - Tuning & Mods 23
J Need some input please Modified 2011- 2019 Explorers - Tuning & Mods 4
T Fog Lights Rewire, need wiring diagram Modified 2011- 2019 Explorers - Tuning & Mods 2
H Security/remote start experts, I need some insight Modified 2011- 2019 Explorers - Tuning & Mods 35
S 2016 Foglight Bulb Size... Modified 2011- 2019 Explorers - Tuning & Mods 10
H Foglight Bulb Options Modified 2011- 2019 Explorers - Tuning & Mods 97
M HID Foglight retrofit? Modified 2011- 2019 Explorers - Tuning & Mods 8
M Wiring help Modified 2011- 2019 Explorers - Tuning & Mods 6
cbasssssss 2017 Headlight Wiring Question Modified 2011- 2019 Explorers - Tuning & Mods 7
S Wiring UHF radio to regular 2016 Explorer Modified 2011- 2019 Explorers - Tuning & Mods 27
T Trailer Wiring Modified 2011- 2019 Explorers - Tuning & Mods 3
F Power AMP Wiring Path - interior routing Modified 2011- 2019 Explorers - Tuning & Mods 1
R Explorer hitch wiring Modified 2011- 2019 Explorers - Tuning & Mods 9
T wiring diagram for 2014 Explorer XLT brake and rear turn lights Modified 2011- 2019 Explorers - Tuning & Mods 1
T 2011 Explorer Remote starter Wiring Diagram needed Modified 2011- 2019 Explorers - Tuning & Mods 2
R Brake Controller Plug and Wiring Modified 2011- 2019 Explorers - Tuning & Mods 108
teh bishop Mounting / Wiring Radar Detector Modified 2011- 2019 Explorers - Tuning & Mods 154
Similar threads
