- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
OKay I am confused here
Earlier you asked:
Where are the O rings that they are talking about and it was not answered
O rings are between the two halves of the plastic intakes, upper and lower I believe if its a 2000 Ranger Right?
Then you said your EGR sensor DPFE was in a puddle? Meaning melted plastic?
Did you replace it with the unit from Napa?
Then you finally cleaned the MAS and cleared the codes, but they are back.
I suggest you get a code reader, they are cheap, like $29+ and it will save you from running back and forth
If it is still the same two codes and those are the only codes you get then it points to something in the intake since both exhaust banks are effected at once.
It is possibe you killed two 02 sensor at the same time but not likely, check the wiring to them, or they both failed at the same time
and you said water may have possibly gotten into something = you where weeling in deep water/mud?
Make sure the wiring to your EGR sensor and hoses all look good check connections (since you worked in there recently and had an issue.
Check the wiring plugs leading to the 02 sensors, no wires melted, etc. 4x4ing can break the factory sensor clips and the wires can get loose and close to exhaust.
I would clean the MAS again
How did you clean the MAS, did you remove the sensor from the mas body?
Check the IAC, hoses on the throttle body and upper intake for vacuum leaks.
Then consider replacing those O rings, its really not a huge job IMO even with a learning curve.
Just unbolt everything attached to the upper intake, remove hoses wires, etc, remove upper, pull out rings, install new ones.
The O rings are covered on this site. The code reader will confirm codes and allow you to clear both soft and hard codes from the computer memory.
Earlier you asked:
