1995E
- July 16, 2010
- Maryland
- 2020 Ford Interceptor
Hi everyone,
I am at 84K miles now and I have a bunch of error codes:
Here is a list of them:
https://gist.github.com/jamesguan/9a3d8af23c7bd8ce6c8ce6a3551c4768
For those who don't have access to github: https://pastebin.com/raw/ijb1Y3S9
Below is a list of issues and I'm wondering if anyone can toss me their 2 cents on the issues:
Code: P0306 - cylinder 6 misfire detected
The one I am most concerned about is the misfire code for cylinder 6. I am guessing I should.
I've been driving with the airbag light and now, the engine light also came on. It only came up when I accelerated hard on the highway to pass. The engine light would flash and then it would disappear. One time while driving, the I had some kind of thump 2 times, about 1/4th of a second between each other and rocked the whole car as if some kind of bind happened. Accelerated hard again one time and same thing happened, engine struggled and then CEL came on and stayed on.
I am going to try to replace the spark plugs first to see if that helps but I'm unsure how else to approach this problem.
Code: B1212 - Driver Seatbelt Buckle Pretensioner Deployment Control:
I think others have ran into this issue? I'm not sure where the pretensioner is. I would assume it's in the pillar where the seat belt comes from, I fiddled around with it, but the code is still present. Took it into the dealership once for this issue and they "fixed" it. It has come back after 2 years and the airbag light has been staying on.
Code: B1081 - Left Temperature Damper Motor
Sometimes my HVAC blows cold on the driver side, and I guess this is probably why. Has anyone ran into this issue before and replaced the part?
Code: B137F - Steering Wheel Left Switch Pack
Not sure what this issue is. My left steering wheel buttons seem to work, but it's a code nonetheless.
Rubbing/popping noise when turning the steering wheel from the center point
So when I turn the steering wheel left to right/vice versa, it always makes a pop noises at around 0 degrees of turn on the steering wheel. I also get a lot of popping noises going over bumps and I'm not sure if it's related. I tried to listen for the sound but it seems the pop travels through to both wheels. You can actually feel the pop when holding the actual wheels and having someone turning the steering wheel left and right. Not sure what it is.
Oil Coated Engine mount?:
I also noticed the engine mount has black oil near it. I checked a month ago and the engine mount was still clean. Not sure if that had something to do with the binding or check engine light. Is the mount itself the source of the oil? I don't see any oil leak coming from the engine itself.
I guess it's time to trade in? I want to at least make it to 10 years or 300K miles with this car though!
