SKW1020
- February 27, 2025
- Little Rock, Arkansas
- 2001 Explorer Sport Trac
Thank you so much for the laymens terms! I needed it that way. I'll get better, Hey, off subject, for the last 12 hours or so I have replacing my 83yo dads steering gear box in his 88 B2. tHis is his baby, and he keeps it like a pin! Anyway, I read about yours, and Im going to print it so he can see what all youve done, he will be amazed! His has a jasper v6 no mods really, but it really is clean. Here a few pics of it.Nice!! So the communication wires are connected from port to pcm
The issue is no start and Your scanner will not talk to pcm
So the thought process here is your pcm may not be getting powered up. Now that we know the can bus wires are connected from obd2 port to pcm, we can shift our focus to the pcm not getting powered/ working
So you are going to check pcm power feeds
When you turn the key the ignition switch powers/triggers the pcm/eec relay. It does this through an interior fuse (19) then through the power diode in the pjb (power junction box = fuse box under the hood) and then finally to the relay
The relay then sends battery power to the pcm and several engine sensors (injectors, coil packs, etc) via the red wire. This is vpwr circuit
So you want to check the grounds, which you did. The ground wires at the pcm should have continuity to ground
Now you are going to check the power side of the pcm
So to do a power check, basically test for battery voltage. Put your multimeter ground lead on the - at the battery terminal and the + red wire probe is your tester
First test pin 55
This should be power all the time. Keep alive power, battery voltage constant to pcm
Next test for power at the other power feeds, this time with the key turned to run
You should have battery + voltage at pins
71 and 97
