I6CJ7
- March 14, 2025
- Manassas, Virginia
- 2000 mountaineer limited
Just replaced the driver side CV axle, and now I have this squeaking sound which turns into a kind of whirring noise from 1 to 25mph.. It's like if you wet your finger and drag it across a window noise. Install went fine, torqued the axle nut to 180ft lbs, the diff side popped into place at the correct depth.
When I jacked up the front end and slowly rotated the axles I thought it was the boots bellows rubbing on each other. So then I put both A-arms under jack stands to drop the suspension down to its ride height. I spun the tire and the noise is coming from where the CV rests in side of the knuckle, up against the wheel bearing. On a whim I shot a spray of silicone lube at it while turning it. And it immediately made the noise disappear. Course after a few miles it came right back.. Not sure what's going on. Haven't had time to pull it apart again. It's like the CV of the rubber on the end? Is chafing the hub, knuckle, or outer part of the wheel bearing where it doesn't spin.
The noise wasn't there before replacing the CV with the disintegrated boot. Wheel bearing felt snug, smooth, no noise.
