New Headlights | Ford Explorer Forums
New Headlights
Nixthebomb
Oklahoma City, OKlahoma
'99 Explorer Sport
Been wanting to replace my headlights, anyone have a good alternative to the OEM that are of good quality that won't get moisture build up, or yellow? I really want something clear
have you searched?
Yeah, not really sure what I should be looking for like an specific brands to look for, brands to avoid? that's ,mainly why I was asking
silver star lights are good. are you looking for an h.i.d. kit? or do you want the lights have some blue tint, or just bright white?
I think he's looking for the entire headlight housing, not just bulbs.
Yes, entire headlight housing, wanting a pure white light, now whether that be HID, or LED I just want it pure white
The color of the light output is going to be based on the bulbs, not really the housing -unless your housings are old, plastic, and fogging/yellowing. You can go with Silverstar bulbs, like mentioned above. I heard the light output is pretty bright/white from them, though I admittedly have no personal experience.
If your current housings are fine you should only need to change the bulbs for different light output. However, if your current ones are shot, I'd check out ebay for some clear replacements. I have a pair of 'Eagle Eyes' black diamond headlights for 2 years now and they're still good as new - no fogging, no moisture. That company may have some clears for the X.
i have the silverstars in my explorer and HID's on my camaro.
silverstars are great altho they dont last pending on if you drive alot at night. if you drive one in a while. go silverstars. all the time at night. go HID's its worth it.
No my housings are looking pretty cloudy, so I'm replacing as soon as i can, which may not b long if I can talk dad into pitching in
Does anyone know if Anzo is a good dependable brand?
oh and can I put a HID bulb in any housing or do I need a special kind?
Another question, how much does a HID kit usually cost, and what's involved in installing one
you can put HIDs into any housing if its the right size. the explorer is 9007 i believe.
as for HIDs. the are easy to install. DONT go to ebay on this one. your gonna have to hunt for the best deals. I got antsy with my camaro and spent $130 on my kit. i found a place that will sell me a kit of the explorer for like $60. reputible place to. check a bunch of car forums. I found mine off Ricekiller.com
I bought a set off Rock Auto's website, and they're great- no moisture, and look great.
There is a coupon for rock on here, they are also a forum sponsor.
Oh, another story in the line of "bluer is not better" - I have HIDs on my car; I ordered 4100K bulbs but they were out of stock so they originally shipped me a pair of 5000K bulbs. If you've been following all the hype, you know that these are supposed to be even closer to daylight color, and even better for visibility.
Well, oddly enough, they were true to their word, and it sucked. During twilight hours, around sunset and during sunrise, the headlight color matched the daylight color perfectly, and so you got no visual feedback that the lights were on. No visible beam pattern on the pavement or road signs. If you were unfortunate enough to be driving at these times, you couldn't see any better than if your lights were off. With a yellower headlight, (I now have 4100K bulbs, as I originally wanted) even if the light intensity is the same as before, you can see more because there's *contrast* - you can see shadows and details and you can read road signs.
Here's another fact about human eyesight - it works on edge detection. When you have sunlight and headlights both the same color, even if the sunlight is relatively dim and the headlights are relatively bright, your eyes are going to act like there's no information coming in, because there's no contrast, no edge information. When you have headlights of a contrasting color, your depth perception improves dramatically, because your brain can cross-correlate overhead shadows from the sunlight against the beam shadows of your headlights.
Granted, these periods of time are relatively short, maybe an hour or so at most, but they also tend to be intervals that you most need to be on the road, if you're commuting. It's just another factor to add to eyestrain and stress. Not good.
Silverstars are the best
Nope. Blue-glass bulbs are never, ever the right choice for optimal safety performance (seeing) from vehicle lamps -- period. It does not matter whether they're branded PIAA and cost $40/bulb or branded Sylvania and cost $40/pair or branded anything else and cost anything else. Blue-tinted glass does not make the light "whiter" or "brighter" in any way, shape, or form. It does not improve anything about the light. All it does is change the appearance of the operating lamp and reduce the beam performance. It's just simple physics, really.
Presently the best 9007 bulb is the Philips Xtreme Power. It runs right up gainst the upper limit of allowable flux for the 9007 (HB5) bulb type, has a very high luminance, compactly-wound filament very precisely focused within the bulb glass, and does not filter the light through blue or other-color glass. That is the recipe for optimal performance out of a bulb.
Ok... THAT was a good reply! :D
Good writeup corey!
Most aftermarket housings are generally of poor quality compared to OEM, though some aren't too bad and could be considered a decent replacement compared to the costs of buying new lights at dealer prices.
My suggestion would be to buy a set of the OEM Ford lights off ebay. I see NEW headlights for the 95-2001's on there all the time for 99 cents to 9.99 a pair from dealers going out of business or getting rid of old stock parts that didn't sell. Grab a tube of Permatex clear silicone from walmart or the auto parts store and run a thin bead all around the lens/housing seam to prevent future moisture penetration. You might also want to get some 3M clear bra to stick on the front of the lens to prevent any yellowing, or make it easier to clean off.
Other members have had good success with the "diamond" type aftermarket lights, though. They do tend to be expensive, and apparently don't have the same moisture issues as other stock-type lights.
Don't bother with any "HID" kits. Get real HID lenses/housings and stick them into the stock housings or something if you must, but please don't get the crap "HID" bulbs and blind other drivers with bulbs that glare because they aren't made for the relectors and lenses they're being used with.
Dude whatever. I have an HID kit and I have never been flashed by anyone EVER. Have also driven by countless cops that have never even looked my way.
I just installed a full plug and play hid kit from ebay for 46 shipped. They look absolutely awesome. My headlights where foggy so I polished them up. If you go to home depot they have a set of 3 polishing wheels for your drill. It also comes with 4 polishing compounds. If you use the softest one, the white jewelers rouge compound, a couple passes is all you need. I then hit it with a pass of 3m rubbing compound. Then waxed them. They look good as new. It maybe took 40 minutes total if that.
I think the kit from home depot was around 10 bucks.
I agree with IB. I have got into a couple other cars and let my friends drive my ex since I installed them. If you take the time to adjust them they wont be blinding to oncoming traffic. I actually have mine set to factory height, I just angled them very slightly to the right.
