You can change the auto transmission fluid, by either dropping the pan and then putting it back up, fill up, spin it through the gears, then repeat. You would probably have to do this four times, 12 litres. Or take a line off of the cooler, pump 1 litre out put 1 in.
Make sure only Mercon V is used, Ford Spec WSS-M2C-202B. This stuff if quite dear. Rougly 9.00 per litre, so for 12 litres you are looking at over 100.00.
I think you can also use Mercon V in the Transfer Case.
