new update from forscan | Ford Explorer Forums
MotorCityFats13
Flatrock MI
2007 Explorer XLT 4.0L
I was finally able to turn off the seatbelt minder and it works now..... no more annoying dinging when the GF refuses to use her seatbelt I also was able to change the oil reminder to 10,000 miles / 1 year and a new function was added called "Police Speedometer Offset" it started at 85 and i changed it to 80 and 90 and I didnt see anything change with the speedo vs GPS unlike before the values would change but switch back when ever I would reconnect and now they stay
Maybe you can answer a question I have regarding Forscan. It seems that he keyless entry pad on the door has been turned off on my 2010 Mountaineer. I found the keycode but it doesn't unlock the door. Then I looked at the status of the keypad and it is set to "off." I can't find where the toggle is to turn it on. Do you have any idea where this is located?
for some reason keypad enable/disable sounds familiar unless im completely imagining things because I saw autolock/unlock disable
weather got cold again but once it warms back up ill take my computer outside and look for it
I did find the autolock/unlock. That item can also be toggled on and off with the info system via the instrument cluster display. I just don't know much about the ins and outs of Forscan since I just started using it last weekend.
the problem is you can edit alot but you need to be a hexidecimal coder i was working with someone trying to turn off tpms and i worked on other explorers but wouldnt on mine
Me doing hexidecimal coding would be a disaster. I might need to break down and take it to a Ford dealer.
