How to: - New Forscan Update Allows Module Programming | Page 52 | Ford Explorer - Ford Ranger Forums - Serious Explorations
How to: New Forscan Update Allows Module Programming
larry91403
2018, Explorer Ltd
Callsign
WQWF829
I think you are SOL. I am pretty sure those air pumps get hot and burn out pretty fast is why they don't do it. I normally let it run its course on a long drive then let it set for ten or fifteen minutes before turning it on again.
Do you think a better tactic would be to (if possible) extend the run time? If settle for 1 hour vs 20? Minutes. The dealer didn’t think there was a run length issue. And I have been restarting them over and over and over for a year now. The only issue I’ve had was it burnt out the switch on the seat.
Mlarv5
Crossville TN
2017 Platinum Ruby Red
I think you answered your own question. You have already burnt out a switch by running to much current though it for to long. There is no way to extend it past the twenty minutes that I know of. As for a dealer service person telling me they don't see a problem with something, I take that with a grain of salt. I have worked around electronics for 41+ years and have been teaching it for 15+ years in one way or another. The switch's are the weak part but the motors are not far behind.
larry91403
2018, Explorer Ltd
Callsign
WQWF829
You're probably right. Maybe if I keep putting in warranty claims for the switch, ford will deal with the problem. :p probably not.
Exploder82
IL
2016 Explorer Sport ;p
Yes, dark mode works fine for me but the Platinum IPC doesn't support controlling it so I have to use Forscan to turn it on or off. Silent mode is what dark mode was renamed to for the 2017MY. I am unable to test this since I have a 2016MY but if the dark mode enable works on your car, that is the same feature. I have a feeling that both must be enabled & the silent mode BCM location controls which keys it is enabled on. Your Sport should also support IPC control.
http://www.fleet.ford.com/resources/ford/general/pdf/police-vehicles/2017 Police Interceptor Utility New Product Updates 3-14-16.pdf
The 2018 Interceptor brochure refers to Police Silent Mode & Dark Car Feature
http://www.fleet.ford.com/resources...chures/2018/2018_PoliceInterceptorUtility.pdf
On my 16 Sport, can I control dark mode from the IPC? I don’t see an option to enable it.
KayGee
Farmington, MI
'16 & '17 PIU
AFAIK, no ipc option for you - you can only enable and disable with forscan or IDS.
Exploder82
IL
Anyone with a 16 want to try the headlight halo as drl’s? I can’t get it to work on mine and curious if it’s a 16 issue or just mine. In the bcm line 726-26-2 x1xx xxxx. The 1 enables it on an 18 for sure. I can’t get it to work on my Sport.
Ntrain
2016 Explorer XLT
I couldn't get it to work on my 16 either.
I think you could try using the parking lights as the DRL and it would use the signature lights.
Exploder82
IL
I didn’t think of that. I’ll give that a try. Thanks.
Exploder82
IL
So that didn’t work. If you change it to turn signals, high beams or whatever those lights just work in conjunction with the halo and low beams. There has to be a bit somewhere that’s hiding to turn off the low beam function of the drl. And if you turn off drl in the ipc then the high beams etc turn off along with the halo and lows.
dont slow down
Elizabeth City NC
2022 Explorer Limited
Has anyone come across a way to get the current gear displayed on the IPC? I can view the tachometer, and when in manual mode it displays the current gear, is there a way to have the current gear shown while in drive too? I have not seen it in any of the spreadsheets, but mine could be out of date as well. I have a 2013 by the way.
RedDen
Calgary
2012 Explorer Limited
It is only displayed when gear selector is in M mode, dont think it is possible on restyle either, maybe new Explorer.
Exploder82
IL
Can anyone confirm when changing the splash screen that it works at boot and close? I swore it did and now it’s showing the ford logo when I open the door when getting out.
Ntrain
2016 Explorer XLT
No way in forscan that I have found. It can be done in HP Tuners though.
MM07
MA
2018 Explorer Limited
If anyone interested, I did it on my MY12 Explorer (Canada):
2. Activating equalizer in radio module itself (ACM):
ACM 727-01-02 x*xx, * change to values from 1 to F (people from russian forum telling either 7 or 9 are the best). I entered 9.
0=EQ Selection #0, 1=EQ Selection #1, 2=EQ Selection #2, 3=EQ Selection #3, 4=EQ Selection #4, 5=EQ Selection #5, 6=EQ Selection #6, 7=EQ Selection #7, 8=EQ Selection #8, 9=EQ Selection #9, A=EQ Selection #10, B=EQ Selection #11, C=EQ Selection #12, D=EQ Selection #13, E=EQ Selection #14, F=EQ Selection #15
I know you posted this awhile ago, but how does 9 sound?
RhinoQuartz
17 Explorer Base
Has anyone been able to understand why certain functions are stored where they are?
Or does anyone know if there's a knowledge repository in IDS that details all the addresses?
Or how to decode them?
MM07
MA
On the IPC, I enabled "Frost Telltale" and "Traffic Sign Recognition"...we'll see what those do and if I notice a difference.
Here is a pic of Frost Telltale icon in the IPC.
RedDen
Calgary
Its unlikely to change anything.
Frost sign appears when temperature drops below 4deg C, it is been a feature on Europe's Fords for ages.
Traffic sign recognition is unlikely to work since it requires a front camera and a proper software, I think it is only available on Explorer because it shares same platform with Aviator.
RhinoQuartz
17 Explorer Base
Aviator is built with the 6th gen, not 5th, so that's not it.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
In nearly 57 years of driving in Canada, I've never needed a popup on the dash to tell me the road might be icy.:)
MM07
MA
Peter and RedDen, I just added it in FORScan in the summer. Not sure what it did. Now I see a cool icon.
I know when it is cold here too!!
