Expl01
- June 16, 2011
- Location
- Southern Cal
- Long Beach, CA
- 01Expl XLT 4.0V6 2 WD 4dr
Hi everyone!
I have been reading this forum for a while, and the exchange of information and maintenance tips has been great. But now I have a problem.
“01 XLT 2WD 4.0 SOHC A/T was running fine as usual, parked it at home, then the next AM it would not start. There was No CEL showing, but I ran the scanner anyway and it showed no codes.
Now: The engine cranks strong, near new battery, so battery, starter, relay, etc are all Ok. Pull a spark plug, ground it, crank the engine and I can see solid spark at the plug, ignition must be Ok. Schrader valve check: fuel spurts [but is pressure high enough? Fuel Pump is new]. Check inertia switch: button not up. Still no start: Why not? What is left?
Could the Timing be off, timing chain jumped 2 or 3 teeth? Would that set a code if the Cam/Crank Timing were off? Would it have run rough last night when it was running? There were and are no unusual noises before or now when I crank it.
If something happened when I tried to restart in the morning, would it set a code? Does the engine need to have been running for some length of time in order to set a code?
Jake
_________________________________________________________________
Jake
