- January 22, 2007
- selkirk, manitoba
- 98 supercharged 347 sport
i just swapped motors. 97 sohc (running) into a 01 sport (not running). there are no codes, there is fuel, and there is spark. using a snap on scan tool, it has no codes present. when i did the motor swap, i took all the harnesses from the 01, and put them on the 97 with the intake, fuel rail and injectors. the only two i didn't swap was the cam and crank position sensors (according to rock auto they are the same part number). motor will crack, but not fire.
