Hello Craftsman67 ,
The cc on my 98 Mountaineer is doing the same thing as yours : doesn't turn on / no indicator light (although it was working fine a week ago). So, I tried the self-test you mentioned and, likewise, I was not getting and light flashes from the right side control buttons.
I checked the wiring to the switch on the brake master cylinder (is that the 'deactivator switch' you mentioned in your 1st post?) and found a lot of brake fluid had gotten into the switch connector, one the wire harness, and into the in-line fuse holder. I cleaned the connections and the fuse as best I could with paper towel and put everything back in place.
Now, the diagnostic performs the single flash through all the buttons and returns a two flash code at the end. The code list I found on the internet says that two flashes means "Brake Pedal Position (BPP) switch is defective, circuit is defective, or brake pedal is applied". So, I guess I need to get a new master cylinder switch and maybe a new BPP switch.
I know you replaced just about every switch on you CC system - did you replace the BPP switch also?
