rick_king
- January 2, 2013
- 2006 Ford Explorer XLT
I have an 06 Explorer. Suddenly have no reverse. No warning signs, leaks, lights, codes, etc.
All other gears work including 4 hi & Low.
When I put it in reverse, the car doesnt move. If I give it gas, the engine hesitates for a brief moment, then the rpms increase (as if I was in Neutral), but doesn't move.
I have been told that the reverse band is gone and now requires a rebuld. But the reverse band is used by 4-low as well...and 4-low works just fine.
There is a reverse servo bore issue that occurs when the servo pins start to wear due to unnecessary (Ford known issue) friction between the housing sleeves and the steel pins. . how could this be determined without removing the servo pin and inspecting it? Usually worn servo pins will WEAR and introduce the failure over time resulting in slippage or hard shifting right?
Reverse Solenoid? Could this be the answer? How can I trouble shoot the solenoid pack (specifically the reverse solenoid)?
I have also heard some chatter about PCM failure. Any help is very much appreciated...
Thank you
Thank you
