Parker Lewis
- January 22, 2012
- 1997 Explorer XLT, SOHC
Hey guys, I'm new here, been lurking for months but finally decided to join because this is a great forum with a ton of help, so thanks for that. Before I start please know that i read about 20 threads on fuel topics and searched a ton of times on this forum. This forum is awesome!
OK, my 97 Explorer (see sig.) has 106k miles, I have all the records from the original owner and I believe this truck has the original fuel pump still. Drove it on a couple of errands last Sunday, about 20 miles in all. Went to start it later in the day and it just cranks and won't start. Sounds like it's not getting fuel. I had my wife cycle the key and I put my head by the rear wheel well and I definitely hear the fuel pump spinning back there when the key is in the on position. It'll wind for about 2 seconds, the typical fuel pump high pitched whine. Then just to make sure, I pulled out the fuel pump relay under the hood and stuck my head back there again, no fuel pump spinning, so i know i'm not just hearing random noises, power is definitely getting to the fuel pump. So then I took off the cap on the Schrader valve on the drivers side fuel rail on top of the motor, i pressed in the little pin inside the valve, and it just dribbles gas. I would think it should squirt gas under some good pressure, for sure more than a dribble, maybe squirt several inches out of the valve. Anyway, i cycled the key a few more times to prime the fuel pump and same result, just a little dribble of fuel from the Schrader valve.
So, is it possible the fuel pump is in fact running but just not pumping enough pressure? The fuel filter was replaced just 15,000 miles ago so I'd like to think it is good.
For comparison I did the same thing to the Schrader valve in my 2011 Ram and it squirted a good foot of gas out of it! Could have shot a low flying bird out of the air! I know the Ram is probably returnless fuel system so its under higher pressure, but its all I had to check it against.
Any help is greatly appreciated! Thank you for taking time to read this.
