XLTmodifire
- February 15, 2010
- Nor*Cal
- 99' XLT (B4 Autumn Brown)
So I get off work, and move the X out of the spot to park my work truck keeping it running. I get back into the X and start driving, noticing that the "O/D off" light is on. Well, I didn't want to get onto the highway w/o OD, so pull up next to the office, and turn the truck off. I then attempt to start it up again, and it fails to start up. The engine turns over, but would not start up.
I let it sit, pop open the hood to find anything loose. I attempt to start it up again just for it to fail. I then decide to leave the key in the on position. Thinking perhaps letting some fuel get in or something. I am not a mechanic. Hell, I wouldn't even know what to look for even if there was something wrong under the hood.
I let it sit in the on position for about a minute, and then attempt to start it again. It tried, and then finally, it catches. Slowly, but finally I was able to give it some gas, and I kept it at 2.5 - 3 RPM just to make sure it stayed running. I slowly let the RPM's drop, and it stayed just fine at 1 RPM idle.
Drove it home, and all is OK. What do you think it could have been?
Thank you for your input. It is highly appreciated.
