OneofMany
- December 21, 2012
- Georgia Mountains- Talullah Falls
- 94 expl 4x4
Hey guys, I did my rear brakes 6 months ago and had a sudden failure the other day. The brake pedal dropped way down when trying to stop and there was an odd noise in the rear brakes. I found that the adjuster had completely fallen out of its spot and was just tumbling around where it could.
I bought all new shoes and adjuster parts, put everything back together.
The shoes seem offset forward, putting the drum on is hard as you have to push the pads rearward to get it on and adjust it very loose to not drag too much. I think this is the same issue I ran into the last time and the cause for failure was a very loosely adjusted brake.
The cause for the shoes being offset is evidently the root of it all. I can move them back, but they don't want to.
Logically I assumed something was not assembled correctly, but every diagram I found confirmed it was correct. All the return springs are on the correct places that I can tell, the adjuster cable runs on the side of the adjuster lever and the lower return spring hooks to the adjuster Pawl and the front of the shoe. The cable guide runs under the top rear return spring and the tensions all seem right. I do not see what is pulling the shoes out of line. Has anyone had similar issues?
