429CJ-3X2
- November 6, 2009
- Des Moines, Iowa
- '01,'02, '04 Sport Tracs,
Roughly 6 months ago I was driving my '02 Sport Trac (114,000 miles) and as I braked at a stoplight, the brake pedal went almost to the floor. No warning at all. The brakes felt entirely normal on the drive to work and up to this point on this trip. I stopped and put some brake fluid in - it was really low. Brakes have worked fine since. No further issues until last week. As I braked at the end of our street, I heard a loud pop and felt it through the brake pedal, and the pedal went a little soft, but not nearly as bad as 6 months ago. The truck had sat for a few days, and we'd had several inches of snow during that time, so I figured the brakes had gotten some moisture on them and frozen stuck until I braked. That wouldn't explain the soft pedal though. Brakes worked fine the rest of this short trip. It was somewhat low on fluid, so I filled the master cylinder for the first time since 6 months ago.
It's repeated the pop and soft pedal several times since, although the pop hasn't been as loud or severe since that first time. Mostly I feel it in the pedal rather than hear it. Seems to be coming from the pedal/firewall area. When it happens, there's no pull like only one side's grabbing, and the next time I brake, even if it's immediate, everything feels normal. It hasn't leaked any fluid since I refilled it last week, but I've only driven it 50-60 miles, a mix of in town and on the freeway.
There has to be a leak somewhere, but I haven't found any visible signs of a leak. I haven't pulled the wheels and drums, but all the lines and connections I can see look good and dry, even the junction block at the rear axle housing.
It's puzzling that it happens so randomly, and the next 20-30 or more times I brake, it's fine. Ideas?
