bizzs
- May 28, 2010
- Gibsonia Pennsylvania
- 2018 Ford Explorer XLT
I am trying to remove a brake booster from my son's 95 Buick skylark and the nuts are located under the dash. The stem from the booster is mounted through the firewall under the dash, and the nuts are very hard to turn with a socket. The nut is not damaged on the outer stars and the socket grabs it fine, but the problem is, the nut is 3/4 of the way off and spins. I tried to get a screw driver behind the nut and turn the socket, but it appears to be stripped.
Anyone have ideas on how I can get this nut off? There is minimal room to get my hands up there because of metal brackets, and it is very confined working conditions. I am out of ideas and hope someone can give a little insight.
Thanks
bizzs
Thanks
bizzs
