Koga
- December 17, 2010
- Location
- Elma Wa
- Elma Wa
- '92 Explorer e.b. 4.0 efi
911 in a big way. Please help my dd is out of commission!!! K so I did a test run after lift and tires and almost back slid into a mud hole made for tires out of my league. I had 2 options go right into about 4' of water and no snorkel or go left into the 35" tire area. I went for broke and went left. I got trough everything until the exit and high centered front and rear diffs. So after getting pulled out I noticed a sound that I can only explain as a ratchet dun gone retarded. I am sure I blew the stock auto hubs maybe stripped something in the front differential. Its a couple hundred bucks for warn hubs and kit. Which I don't have. A buddy says he will hook me up with front and rear axles from a 78 f series truck. Problem is I don't have the experience to put them in or where to start. Will these axles work they are I believe a dana 44 in front and a true 9" rear end the front has 4" lift coils already on and 4" leafs in rear. Where do I start any help would be greatly appreciated.....
K so I now need to update damage is worse than I thought. Hubs axles have to wait I am leaking coolant in between what seems to b the tranny and engine it isn't a drip more like it is pouring I can see it coming from what looks like a metal gasket. I NEED HELP I have no idea how to fix it and can not find a thread close to it. The leak is coming from passenger side I just put 2 gallons of water through it. Any ideas would be great.
http://s1349.photobucket.com/user/Koga1980/media/20140307_155517_zpsa2bc4d97.jpg.html?sort=3&o=7http://s1349.photobucket.com/user/Koga1980/media/20140308_155347_zpsa700ead1.mp4.html?sort=3&o=0
http://s1349.photobucket.com/user/Koga1980/media/20140307_155536_zpsd1198513.jpg.html?sort=3&o=5
http://s1349.photobucket.com/user/Koga1980/media/20140307_155530_zps740b9cb0.jpg.html?sort=3&o=6
