explorerluv09
- June 12, 2009
- boston ma
- 92 xlt
Hi all,
This is the first of a few posts regarding my 92 XLT.
I've had it for a little over a month now, and while the "honeymoon" period is still going, I've encountered a few issues. I must have hit a bump a little too hard one day, because now I'm starting to leak both oil and power steering fluid.
The first thing I notice was the oil. I first noticed an occasional drop or two on the ground if the car sat for a while.
Now, after about five minutes of driving, smoke comes out of the engine with the smell of oil.
I traced the leak and found oil seeping out of the bottom of the oil pan. It's a very slow leak, and the oil pools up around the edge of the pan and eventually drip down to the ground.
I believe that the smoking occurs when droplets of the oil get sprayed into the engine compartment while the vehicle is in motion.
As you look at the pictures, I wiped the pan and can see that the oil is seeping from a hairline crack along the seam of the pan:
I hope someone can tell me of an inexpensive way to fix this.
Other forums suggest that I will have to have the pan either welded or replaced, and from what I've seen in the Explorer Manual, I would have to turn the engine over to accomplish either task.
Can this repair be made with JBWeld, LocTite, or some kind of epoxy? I honestly don't have the money to have the mechanic work on it, and the fix seems to be so simple.
As always, I really appreciate the feedback and suggestions from the members of this forum.
Thanks!
Thanks!
