donalds
- July 12, 2015
- Location
- Stem
- Nc
- 1999 ford explorer sohc
I had a oil Leak
I wasn't sure if it was coming from the upper oil pan gasket or the rear main seal it's easier to start with the gasket here's what I found
I'm not sure if it leaks is gotta drive it
The little tabs on the gasket are for the rear of the oil pan the little tabs go up in the rear bearing cavity I think these were not but I'm not sure
By the way no plastic in the oil pan at all
1 side of this part of the gasket was squished more than the other
