Explorer Forum Covers the Explorer ST, Explorer Sport, Explorer Sport Trac, Lincoln Aviator,
Mercury Mountaineer, Mazda Navajo, Ford Ranger, Mazda Pickups, and the Ford Aerostar
Register Today It's free!
- Forums
- Generation Specific Forums
- 1995 - 2001 Explorer Ranger Merc. 2nd Generation
- Stock 1995 - 2001 Explorers
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an alternative browser.
P0174.
- Thread starter Chris1973
- Start date
Add an avatar, upload photo attachments, and more!.
DintDobbs
- January 29, 2020
- Location
- somewhere in the swamps
- NC
- 1999 Explorer Sport 4x4
@Chris1973 That is probably from one of two factors. You'll have to explain the actual effects; elaborate on "loss in power" and "sloppy start" for us a bit. Is it choking out after starting? May be stalling under heavy acceleration? Does it crank all day but only start once in a while? Does it idle rough? Run high temperature?
"Loss in power" and "Sloppy start" could both be unrelated to the code. I replaced my downstream O2 sensor when I had that code, and it fixed the problem I was having (faulty sensor thought it was running lean, started injecting too much fuel, choking the engine on accel, low-RPM rough idle) at the time. Since then, the code has come back, but the symptoms aren't the same.
Explain the problem just a bit more, and you'll be swarmed with responses and helpful suggestions.
- December 22, 2021
- Los Angeles, CA
- 1998 XLT 4x4
24 Rngr 4x4
^^^ for this ill bubble in E, for need more info@Chris1973 That is probably from one of two factors. You'll have to explain the actual effects; elaborate on "loss in power" and "sloppy start" for us a bit. Is it choking out after starting? May be stalling under heavy acceleration? Does it crank all day but only start once in a while? Does it idle rough? Run high temperature?
Pete Deering
- November 13, 2019
- New England
- 1995 xlt 4 door 4x4
Check for a vacuum leak on bank one ,check if a vac hose is off. You can used carb cleaner or brake cleaner. Also look on the bank one exhaust manifold for a leak.Need advice.the map sensor is new.what are the next steps to check on this cod?
- September 23, 2020
- Location
- United States
- Alabama
- 99 Explorer XLT 4.0 SOHC
Check vacuum lines especially the one for the vacuum ball under the passenger fender liner also make sure none of the plastic lines are crackedCode is for a lean bank one.causes loss in power a maybe sloppy start .
Chris1973
- January 31, 2022
- Malvern,pa
- 2000 Ford explorer XLT
It starts but it shoots real low on the rpm then it idols at 1000 for a few.power is down and I am getting a lot of shifting issues.feels like the truck is jumping at 35 to 45 mph.and it shifts alright but wants to downshift alot.@Chris1973 That is probably from one of two factors. You'll have to explain the actual effects; elaborate on "loss in power" and "sloppy start" for us a bit. Is it choking out after starting? May be stalling under heavy acceleration? Does it crank all day but only start once in a while? Does it idle rough? Run high temperature?
Chris1973
- January 31, 2022
- Malvern,pa
ThanksCheck vacuum lines especially the one for the vacuum ball under the passenger fender liner also make sure none of the plastic lines are cracked
The truck starts all right. But it bogs down to like 3,000 RPM like it's going to stall and it kind of idles it a thousand for a while. It loss of power and it's just really really strange it seems to shift all right but it bucks at about 35 to 45 miles per hour and it seems like it wants to downshift a lotWe need way more info
94Eddie
- September 18, 2003
- 2010 Mountaineer Premier
For this type of code it is very helpful to see what the long and short term fuel trim readings are doing. Here are two videos that explains this better than I can type it.@Chris1973 That is probably from one of two factors. You'll have to explain the actual effects; elaborate on "loss in power" and "sloppy start" for us a bit. Is it choking out after starting? May be stalling under heavy acceleration? Does it crank all day but only start once in a while? Does it idle rough? Run high temperature?
DintDobbs
- January 29, 2020
- Location
- NC
@Chris1973 Sounds loosely similar to what mine was doing with that code, but mine was just a faulty sensor. I'll second the others, check for a vacuum leak, that little ball in the right front wheel well (behind the plastic liner) could be responsible. Checking the more detailed computer logs will help, even if you don't need them to solve the problem, getting into that will break you into a world of technical design you may have overlooked before.
TL;DW The CEL is only triggered if an ideal fuel/air mixture cannot be achieved within the parameters of a properly functioning EFI system. You've either got good sensors detecting a real problem, or a faulty sensor is causing the EFI to do the opposite of what the engine code says. My experience says your engine sounds more like it's flooding than starving, so make sure all your sensors are clean and plugged in correctly, clear the codes, and start fresh. If the problem persists, then do the harder stuff.
Chris1973
- January 31, 2022
- Malvern,pa
Thank you@Chris1973 Sounds loosely similar to what mine was doing with that code, but mine was just a faulty sensor. I'll second the others, check for a vacuum leak, that little ball in the right front wheel well (behind the plastic liner) could be responsible. Checking the more detailed computer logs will help, even if you don't need them to solve the problem, getting into that will break you into a world of technical design you may have overlooked before.
Chris1973
- January 31, 2022
- Malvern,pa
Thank youWhaCheck for a vacuum leak on bank one ,check if a vac hose is off. You can used carb cleaner or brake cleaner. Also look on the bank one exhaust manifold for a leak.
T is this black ball and where is it exactly?@Chris1973 Sounds loosely similar to what mine was doing with that code, but mine was just a faulty sensor. I'll second the others, check for a vacuum leak, that little ball in the right front wheel well (behind the plastic liner) could be responsible. Checking the more detailed computer logs will help, even if you don't need them to solve the problem, getting into that will break you into a world of technical design you may have overlooked before.
- December 22, 2021
- Los Angeles, CA
- 1998 XLT 4x4
24 Rngr 4x4
Thank youWha
How to: - 2nd Gen NO AC ( or heat) FROM VENTS!!! A "How to" what to look for thread
Here is what to look for if you have a 95-01 with cold ac, and hot heat, but it only blows from the defrost vent. IF YOU HAVE COLD AND / OR WARM AIR BLOWING FROM DEFROST DUCT ONLY THIS THREAD IS FOR YOU!!! I will immediately delete all ac cooling questions without answer-let's stay on track...
DintDobbs
- January 29, 2020
- Location
- NC
@Chris1973 Here's the little fella you're looking for, in the middle of this pic. It's right behind the bumper under the right fender, your fender will look slightly different when you remove the liner because mine is trimmed like 3 inches. If it's not there, then you've found the problem!
For reference, here's a pic to show where the ball should be in relation to the upper control arm and the shock absorber. The ball is on the far right.
DintDobbs
- January 29, 2020
- Location
- NC
@Chris1973 Oh, and if the ball is there, but the little hose is missing, then that would be the problem.
Chris1973
- January 31, 2022
- Malvern,pa
Ok.i located the ball just need to get something out of the way and it's crappy weather today.
@Chris1973 Oh, and if the ball is there, but the little hose is missing, then that would be the problem.k.
Chris1973
- January 31, 2022
- Malvern,pa
And you won't believe what I found and I know it's part of the vaccum system.its behind the drivers side wheel well.the hose from that black ball when to the intake and another hose out of the intake to this thing.i will get a pic.@Chris1973 Sounds loosely similar to what mine was doing with that code, but mine was just a faulty sensor. I'll second the others, check for a vacuum leak, that little ball in the right front wheel well (behind the plastic liner) could be responsible. Checking the more detailed computer logs will help, even if you don't need them to solve the problem, getting into that will break you into a world of technical design you may have overlooked before.
DintDobbs
- January 29, 2020
- Location
- NC
@Chris1973 Any updates? I know life happens, but I'm a bit curious as to what exactly the "thing" is. Is it stock? Aftermarket? Maybe leftovers from somebody else's hack job? Pics will help us to know. Also, if it's got a part number on it, that might help too.
Similar threads
- Replies
- 3
- Views
- 1,435
- Replies
- 1
- Views
- 1,767
