taylorpro
- May 31, 2012
- 1999 Ford Explorer XLT
Alright guys. I'll give you a quick rundown. I have a 99' 4.0 SOHC. 173k. I custom mounted a 3g alt and by making the upper radiator hose work for the time being, the stock IAC to Intake tube hose wouldn't work. (the molded plastic hose that goes under the intake up to the IAC) So i made one with vacuum hoses. Couldn't ever get the size/length correct so idle wasn't correct. Got the P1506 code obviously. It was high in start up and and idled high. I worked the size down until i got it to a manageable idle. Except it would almost die on cold weather start up since the IAC couldnt compensate at that point.
WELL NOW. I re-routed the upper radiator hose today SOLELY so i could put the stock vacuum line. Thinking that I've just had the size of the line was the problem. And it's STILL showing the light, and its still idling pretty high. around 1000rpm. And on startup, thats the worst. goes up to about 2000 then comes back down. this is uncomfortable to me since i have a higher mileage engines with not so perfect timing chains.
Now, I've checked all the vacuum lines I see around the intake and they all seem ok. All of the hoses in the intake tube are in correctly and the clamps on the tube are tight. The ONLY thing that may be leaking some is the rubber boot between the molded plastic vacuum hose and the IAC itself. I will address that tomorrow. The idle Does go down a bit when i unplug the IAC. And it idles smooth either way.
I mostly concerned about the damn start up Rpm. when its cold and the rev's go that high on startup the chains just cry its no bueno. If i can't fix this im going to just use my ghetto-fab line until i can figure it out. at least it doesnt go up crazy on startup.
If any of you guys can help me out or drop me some plans of attack id really appreciate it.
**I should Note too, that before i started this alt insall, the car idled perfectly fine at about 6-700. Nothing was out of the norm till i put my own line on there and it hasnt been right since. thanks
