pcm/engine wiring harness diagrams.....please help me!!!!! | Ford Explorer Forums
9horseman
bay view wisconsin
2000 ford explorer 4x4
I just recently blew up my 2000 FORD EXPLORER 4x4 4.0L SOHC with vin code x for the engine. Now I have a small problem making the replacement engine I was able to procure is from a 1999 FORD EXPLORER 4x4 4.0L SOHC with vin code x for the engine. What I need to know is if anybody has ever done the swap of these two motors on their own and ran into the same thing with the wiring harness not having the same set-up ends and/or leads to all the sensors. What's concerning me is if the 1999 motor will run in my 2000 body after all the wiring was reconfigured to fit the 1999 motor and does the knock sensor on the 1999 motor have to be hooked up to the 2000 PCM in the same fashion as the 1999 PCM was. I spent a whole lot of time trying to do this and don't want to have another bad motor experience. Anyone have a wiring diagram for both the 1999 and 2000 Explorer 4.0L sohc?
SOHC V6 vin x?
The first thing to clarify is what engine came in your vehicle and what engine you purchased to replace it. For both 1999 and 2000 the 8th digit of the VIN is "E" for the SOHC V6. If the 8th digit is an "X" then your 2000 vehicle is wired for an OHV V6. I suspect that you have different engine types (SOHC and OHV) and are trying to replace one with the other. Since you mention a knock sensor on the 1999 engine that one must be a SOHC - the OHV has no knock sensor. Are you trying to replace a 2000 OHV with a 1999 SOHC?
CMP sensor
If you're swapping from an OHV to a SOHC you'll encounter a problem with the different camshaft position (CMP) sensors. The SOHC V6 utilizes a variable reluctance CMP sensor mounted on the left valve cover. The OHV utilizes a hall effect CMP sensor (synchronizer) mounted at the rear of the engine driven by the jackshaft. The PCM reference voltage for the SOHC CMP sensor is 1.5 volts and that for the OHV sensor is more than 10 volts. Snoranger encountered this problem when swapping his OHV with a SOHC. See:
Did the SOHC come with a cam synchronizer?
OHV to SOHC swap wiring
The reluctor sensor outputs an alternating current signal and requires no power source. The hall effect sensor outputs a rectangular waveform with a 5 volt maximum, has a built in amplifier and shape generator, and requires a power source. In order for the SOHC CMP sensor to be compatible with the OHV PCM a variable reluctor to hall effect converter similar to the one in the following thread will have to be incorporated: MS2-Extra Distributor Pickups Manual
I have the wiring diagrams for the 2000 SOHC and OHV. I suspect there were few changes between 1999 and 2000. The only differences I saw were for the fuel cap sensor, the knock sensor, the O2 sensors (4 vs 3 sensors), and the message center.
Can you send me a copy of those two wiring diagrams? I’m having a problem right now, but it’s not an engine swap. It’s the PCM won’t communicate with the PMC through my scan tools. I’m suspecting bad wiring, but the diagram is not in my possession, so I’m ready to go point the point on the whole harness. I just don’t understand why it won’t communicate and two when the key is off the patch system light flashes as normal but the minute you turn it on the security light goes out we normally it will stay on for a few seconds and then go out to confirm that the pet system is communicating with the computer, but it doesn’t do it. I’m at my wits end so if there’s anybody out there that has knowledge of this particular type of problem normal security light key off turn key on security light goes out immediately no fuel pump no crank and power to the call back is not holding me out please help my brother.
Phew
Okay the obd2 port for your scanner is powered same fuse as the aux power socket (cigar lighter)
Often that fuse blows
Now as far as your pats / theft light issue… the theft light should flash slowly and go off when cranking the starter. If that is happening then the pats security system is happy
If it starts to rapid flash then the pats system has a trouble code and if you let it rapid flash for 90 seconds it will then begin to flash slowly, in sequence, count the flashes and you get your trouble code
This thread is about replacing one engine with another 13 years ago
You may consider starting a new thread for your power / communication issues
