Xplorer92
- September 25, 2004
- Richmond, VA
- '92 XLT/'00 Jeep Wrangler
I'm currently doing a '93 4x4 Explorer rear axle swap on to a '94 4x4 Ranger Rear. I have the new perches, and shock mounts ready to weld on. The only problem is I have absolutly no experience with Pinion Angles. I don't want to just eye ball it when I weld on the perchs and I have heard that it is very important to set the pinion angle correctly before welding them to prevent the U-Joints from binding, and the rear end from vibrating. Should I just set the Explorer axle parallel to the Ranger axle and put them in the same location as the Ranger axle, or is there a better method of achieving this. If someone would be kind enough to give me the 411 on pinion angels for dumbies on this one (in simple terms) please do. Thank You
