SuperEx91
- January 25, 2006
- Toledo, Ohio
- 91 XLT EB
my SAS is in the works at the moment. i was curious how i should choose my pinion angle for both the front and rear. i am making radius arms for the front and have weld-on brackets for the axle, i just dont know where to weld them in regards to pinion angle and caster. Also in the rear i am just doing a SOA and lift shackles. I heard somewhere that i should match the angle of what it is now stock but i am not sure if that is right. Also my ujoints have to be at the same angle to eliminate vibrations i believe.
When i mount my radius arms to the frame, would it be a good idea to mount them close to where the front output of my tcase is? (similar to how the trac bar and drag link have to be parallel) or does this not matter? Thank for the help-Tom
