yah, that sounds a little more difficult than moving the C's. I will plan on that then.
i worked out an order in my head. let me know what you think, if i will run into problems...
1. complete rear(SOA, Lift shackles). this will be height to set the front to.
2. with rear tires on ground, set front on stands at same height.
3. locate the front axle same height off the ground and where i want it front to rear.
4. set axle to desired pinion angle with jack stand or whatever.(this with C's already being removed)
5. place R/A mounts on axle and frame at desired location.
6. make measurements for the radius arms
7. build the radius arms.
8. with arms test fitted, weld axle brackets on at correct pinion angle.
9. weld frame brackets on.
10. tear apart and remove front axle.
11. based off of pinion angle, set C's to 7* and weld.
12. put back together and mount springs where needed to keep angles as set.
Thats what i got so far. the only issues are getting my upper spring mounts set in the right location to keep my angles right. I dont know how the springs are gonna settle, which worries me.
Another issue...moving the axle forward. i have read numerous times about this and don't know if i should do it or not. planning on 36-37" tires if that is one of the deciding factors.
Also saw this in this months petersons mag.
I want to make shock mounts like those. i have those same spring buckets and they could easily be made with square tube i think. they want 215 for them but i think i can make them.
