mikehawk
- March 6, 2006
- South Florida
- 91 EB 4x4
Heat range of a plug has nothing to do with the kernal size of the spark. All the heat range means is the plugs ability to pull heat out of the combustion chamber. I don't know where you heard that platinum was a better conductor, but you're wrong. If that was true, why would the core of the plug be copper, and only have platinum on the tip of the plugs? It's because platinum is a MUCH harder metal, so it can hold up to the abuse of the combustion chamber much better, and therefore last longer. Copper is a better consuctor, but it's also a lot softer (same as silver and gold), so it doesn't last as long. And I don't know how you can measure the gap of the plugs in that pic. The quality of the pics isn't that great to begin with, and the spark kernal floods out the exact outline of the electrode and ground, so there's no way you can just eye it up and dismiss it because you think one gap is larger than the other.
