Ronin8002
- March 23, 2003
- Virginia
- 2008 XLT Ironman
After thinking and learning a bit about how the Rancho Quicklifts work in this thread http://www.explorerforum.com/forums/showpost.php?p=2697205&postcount=18 I think I figured out that the Quicklifts are simply strut assemblies with a coil spacer and an adjustment mechanism to control the dampening of the shock
I started wondering if there was a generic knock off version coil spacer that Rancho uses to achieve the lift in that kit. If there is...then people could just buy that and install it on their OEM strut assembly...gaining lift and saving money over the Quicklifts. A lot of the ones I've seen are made of softer rubber and I think that might have a short life...so I went and looked at Energy Suspension's site:
http://www.energysuspensionparts.com/Energy-Suspension-Coil-Spring-Isolators.asp
Check out Style "D", second from the bottom. I haven't gotten really accurate measurements yet, but one of these universal coil spring spacers might work on the struts we have.
The overal shape is right. It would fit at the bottom of the coil where it sits halfway down the strut. These are all 5/8 in height (except one option that is 9/16")...which I think would give about a 1" lift based on the way our suspension geometry works. It might also be possible to stack another one of those other flat type of isolators on that page underneath the "D" type to get a bit more lift.
Probably wouldn't be good to go too crazy with this though...by installing these you are preventing your coil spring from being able to fully compress, which will limit your uptravel to some degree, however minor...and that might start to impact ride quality.
It's just a question of the other dimensions...there are a few to choose from. At less than 10 bucks a pop I thought I'd throw the idea out there if someone was doing their struts anyway and wanted to try it.
Anybody got any thoughts or ideas?
