timleedude
- April 22, 2003
- Honolulu, Hawaii, USA
- 06 XLT 4.0 6cyl
I have a 99 Exp XLT 5.0L V-8 AWD 4Door Auto.
I Noticed that when using my Manual Control A/C. The vents are either Front Vents (with little coming at the feet) or Defroster Vents (with little coming at the feet). From "OFF" , I turn the knob to the left to MAX A/C and it's COLD with Fronts Vents blowing (and little bit at the feet). When I turn the knob to the Right side of "OFF", all 4 positions blow only to defroster (and little at the feet). If I rotated the dial back to "OFF" and to the left, it stays blowing at Defroster (and little at feet) until I reach MAX A/C where it changes to Front Vents (and little at feet). Does this sound like a vacuum leak somewhere or is the A/C Control Unit bad? By the way, Heat and Cold works fine.. Just having problems with the vents
Thanks
-Tim
Thanks
-Tim
