- September 1, 2002
- Lake View Terrace, CA
- '91 Navajo '99 X '19 Rngr
Well I figure I'd start a thread of this. I'm really not sure where this will go....
So I picked up Keepers 2000 Explorer Sport, with plans to make into a fun toy to wheel. However after getting it home I'm starting to have 2nd thoughts.
It's in pretty bad shape. Much worse then I expected
The whole driver side is toast, and I'm not even sure it can be pushed out enough to be even close to what it was. There is a good 1 1/2" gap between the door jam, where the quarter panel stretched inward. Looks like the front end A-arm may be bent, and the rear axle may be gone too. Everything shifted back there in the accident, and looks like the axle or a shaft is bent.
So at this point it's really going to come down to what the frame looks like. I have to do some measurements to see if it's square, or even close. If the Frame is ok, we will probably go on with the project , just may go a different direction. Less body, more tube. If I can come up with the money I'm thinking F-Toy Cage
However if the frame is toast, there really is no point in going on, there is just way to much damage. At that point the only thing salvageable (besides small parts) is the drive train. Which does run and drive good
Our plan was to drive it home yesterday...as you can see that didn't happen
the rear axle was causing the wheel to wobble so bad we knew we would never make it the 45 miles home. We originally thought it was the wheel, as it was cracked. But after swapping the spare on, it had no effect. :thumbdwn:
