Sorry for the delay, unfortunately life got busy. My Grandmother past away on the 30th of august, and then I started up College again, all of that combined with work makes for a limited time frame, add on top of that, the fact I only come around here once in a while doesn't help the situation
I'm actually away from home for the weekend, but if you have anything specifically that you need help with I might be able to offer my assistance, let me know
Otherwise, the best way to describe the whole process in a general sense is that I cut out the back of the headlight housing, enough so that the FX-r would fit flush in the back (to a degree) then align it properly attach the shrouds, close up the headlights, wire the whole thing up then turn em on!
I know that isn't the best, but its what I have to work with currently, the hardest part is literally opening the headlights up.
For a more general guide, look for the PDF link under the picture @
this link
The only thing I would recommend is NOT to put the headlights in the oven, for me the housings started getting soft before the glue between the lens/body did. I used a heat gun and a HELL of a lot of patience, they are huge headlights.
I hope that helps some, again sorry it took so long.
