Question on wheel sizes | Ford Explorer Forums
Hammerman
Cherry Hill, NJ
94 Navajo LX
Would it cause an issue If I had 16 inch wheels in the back and 15 inch wheels in the front? I am going to replace a bad rim, and my father has two 16 inch wheels from a tribute that he doesn't need.
No issues. When or IF you rotate, just make sure you do front to back and keep the same diameter wheels on the same end of the vehicle. I would use them as a temporary thing though.
ok from taking a wild guess at it, it being a 94 means you have ABS on the front too right?? the wheels are going to throw an ABS light. If its 4x4, do not put different size wheels or tires on, it you shift into 4 wheel drive, it will destroy your transfer case in about 2 hot seconds
As long as the overall diameter with the tire is the same you should have no problems.
