rear abs sensor testing, what are specs | Ford Explorer - Ford Ranger Forums - Serious Explorations
syeht
Green Bay, Wisconsin USA
97 AWD 5.0 V8
Before I even spend $20 I'd like to check my rear abs sensor. Any idea on what range it should read on an ohm meter? Front ones too if you've got that info. But both front read the same.97 xlt awd 5.0L
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
loraine
Rizal
Hello guys
What is the specifications of Rear speed sensor ABS of explorer xlt 2005 4.0L
donalds
Location
Stem
Nc
1999 ford explorer sohc
I don't think there is a real check it is a hall effect sensor
The sensor works with a tone ring
The tone ring is placed near the sensor
The ring has notches in it like a gear
The sensor creates a small voltage
When moved over the notches
That voltage is messed by the pcm
To determine speed ect...
If you get a reading of say 1.5k ohms to say 3.0k ohms then your good
If it reads ..0.. then it is bad
Sometimes the magnet inside the sensor gets week
Sometimes the tone ring is damaged ..not likely..
Sometimes the wire harness is bad or dirty
Good luck
Ps buy a new one
