dmc80
- December 16, 2008
- chicago
- 99 xlt ohv
link did not work
BTW: Order you shocks at shockwarehouse.com, a lot cheaper.
Shockwarehouse is an EF vendor. Here is the EF link to them (can be easily found at the bottom of the page when looking at the list of forums).
http://www.shockwarehouse.com/discounts/goto/167
~Mark
How do they ride though? I've heard the loadlevelers rode much more stiffer than air shocks or normal ones like Reflex? I was going to get the Max-air adjustables to help with rear sagging and they get excellent reviews for ride quality as well.Thanks Mark, Here's the Monroe Loadleveler for the 95-01 Explorer:
1999 Ford Explorer Loadleveler shock.
Just use the discount code "explorer5" for 5% off.
Cheers!
Whats the difference between that and any normal shock like Monroe Reflex? Plenty of trucks use help shocks or air shocks in placements of the stockers to level the ride when towing/carrying heavier loads no problem. Reflex helped a bit with sag so wouldn't that apply then.... I don't see issue with air-shocks or helper springs like the levelers. Only negative I heard on the levelers was they rode stiffer.Not a fan and wouldn't recommend them. They transfer the weight-carrying loads from the rear of the truck to the shock mounts instead of the sprint mounts. The mounts on our trucks were designed to connect the dampers to, not carry suspension loads.
Does anyone have any input or experience using any of the following? I'm leaning toward the KYB Monomax or Rancho 5000
Rancho 5000
Bilstein HD
KYB Monomax
KYB GR2
Trailmaster
ProComp
What's an RSX? I did not see that one. Is it a Rancho too?I guess a hundred-thousand lemmings a year can't be wrong, can they?
The Explorer is not one of those vehicles designed to transfer the weight carrying loads to the shock mounts. Yes, in *some* vehicles they are, but the Ex was not one of them. *Some* vehicles can withstand *some* extra froce on the shock mounts for *some* period of time, but that doesn't mean they were ever designed with those additional loads in mind.
The Rancho 5000s aren't any better than the RSX's IMHO. I'm currently running the KYB MonoMax's on my F150 and love 'em (and I've contemplated putting them on the Explorer too). I'm not a fan of the SensaTracs but some people here love 'em.
I get what your saying, I can see that happening when carrying/towing heavy loads as that would put a lot of stress on the mounts compared to normal un-ladden driving. I'm just using air-shocks in the rear to level out the stock height for the little rear sag on the drivers side. I don't tow or carry heavy loads.I guess a hundred-thousand lemmings a year can't be wrong, can they?
