bronchole
Driveway flexing!
- May 13, 2009
- Los Angeles, CA
- 1997 Monsterneer
- Callsign
- KI6MCO
I want to look in to options for my rear suspension so I can get it caught up to my front suspension. I think I am at about 6"-8" of suspension lift from stock. My front is running 12" of travel (6 up/6 down). I think the up on the rear can go probably about 10" up before the 35" tires start to hit things. I would like to plan for 38" tires. I think that drop will be about 4"-6" from its sitting height. That will be limited by bind on the double cardigan joint at the transfer case. I'll measure that as part of the development.
I am looking for something flexy for rock crawling but capable of adapting to a wide range of load.
I am currently running:
- Full width 1994 Ford F150 8.8
- 35" BFG mud terrian tires on steel bead lock rims
- Traction bar
- 4" lift springs from Summit racing
- axle over and extended shackles (that sounds more like 10"-12" of lift)
- I have to significantly limit the up travel to keep the springs from going past flat.
- Air shocks with internal bump stops. I can air the shocks up for towing or down for flexibility.
Right now I am thinking of a custom set of leaf springs to go back to axle under. That should greatly improve my up travel. I have some 2" air bump stops I can incorporate to limit the up travel. Maybe a limit strap at the differential to protect the driveshaft joimt. For load carrying and towing I could integrate a pair of air bags attached to the frame side and cups on the axles side.
Any other ideas you think I should look at?
- Traction bar
