Rear toe link replacement ? | Ford Explorer Forums
03WIExplorerLtd
2011 Explorer FWD base
Hello, I see that my 2003's rear passenger toe link boot is shot (the drivers side rear looks OK). The boot is all cracked, and tearing (not pretty). It makes a clunk in the rear, and I am guessing it is potentially from this part. I have struts/springs with less than 4k on them, so they are fine.
I see Ford , Moog and potentially even Dorman (according to RockAuto), make this part.
I believe that you have ONLY these options:
1.) Replace with Ford/Motorcraft
2.) Replace with Moog ES800560 AND ES800562 (you would need both I believe).
3.) Replace with Dorman 523007 (if this is a valid replacement)
So with that being said, is this a hard part to replace? Any ideas?
