Received another letter from ford to have the 20S62 recall performed. Had the last recall performed where they replaced the toe link.
Have concerns about the new toe link design. This is the current model that was installed on my 2015 explorer with only 27,000 miles.
This is the new model that ford wants to install.
Note the lack of the toe threaded adjustment link. On the new link, toe in adjustment is performed by sliding the new link between the nut and bolt in the knuckle as the link has an elongated slot, not a hole. So the new link does not allow the mechanic adjusting the toe to have the precision or ease of adjustment as the old link did. here is a video of a Ford mechanic struggling to adjust the toe.
My Dad worked as a Master mechanic in a Ford dealership for over 30 years (I worked there as a kid also). With todays mechanics being rushed to produce and meet quotas, many mechanics today are forced to perform work that is “just good enough” and not high quality. How many mechanics do you think are going to take the time to get this alignment performed properly messing with what amounts to a pinch bolt, not a precision threaded rod?
Why am I concerned? Have read owners having issues with tires wearing out because of improper toe after the latest recall. At least one case can be found on this forum. So whether the mechanic did not set the toe correctly during alignment or whether it changed after is up for debate.
The end result is the same, the owner has to fork out big bucks for 4 new tires.
Personally, I feel this is a piece of crap way to adjust and hold toe. It should be a threaded rod that is “locked” in with a locknut, the way the old link was. My opinion is since the link is elongated the first big pothole you hit is going to move the link and change the alignment. The new link is only pinched by the knuckle bolt, not locked into a round hole like the old link. The old link did not have this elongated hole and the only way the alignment could change is if someone adjusted the threaded rod.
Ford eventually figured out the toe links were breaking because the toe link ball joint was seizing in the knuckle putting undue strain on the toe link. The new unthreaded rod is overkill because they simply did not know why they were breaking in the beginning.
So rather then have ford putt a half a$$ link on my vehicle (and possibly cost me a new set of tires) just going to crawl under there myself and perform a test on the knuckle ball joint. Doubt it will be bad at 27,000 miles because we never drive it in the snow or bad weather ( we use the 1994 explorer for that).
Curious on what your opinions are on this “updated” toe link.
